Project data & BIM
Merge uniform items missing?
qingdom
I can't find merge uniform items in schedule in AC26?
I only have merge items which merges everything and i don't know why would anyone merge everything that is not the same.
Did the setting move?
AC27 INT | WIN10
14 REPLIES 14
Yes, there it was. I didn't know of that setting.
Life changing. Thanks
AC27 INT | WIN10
Thank you all so much.
AC 28 INT 3110/WIN 11
qingdom
Still to the same topic of schedule, just set the calculation to be centimeter to all it shows but the profile height column is showing in meter.
Why this column is not affected by the global setting of centimeter?
Is there a setting for this to change in centimeter and not in meter?
AC27 INT | WIN10
In calculation units set length to be measured by centimeter.
As i mentioned, i already set the calculation units to be measured by centimeter.
All columns are by centimeter except that one.
AC27 INT | WIN10
