Project data & BIM
Metal Cladding
Hi there im wondering if anyone can give me an idea of how can i do a metal cladding composite structure layers, what are the layers? i'm kinda have an idea but i just want to see how you guys would do it. I'm posting a view of the building, you can take a look at the finishes. Thanks people
lovetrain
6 REPLIES 6
I did a project recently that had a metal cladding for siding. I'm not shure if this is what you are looking for but this is what I did. I made a thick outer composite layer with a metal exterior material. Then I used small walls as a SEO operator on a hidden layer to give it a corrugated look.
Djordje
You can also use the cladding library parts; however, that adds quite a few polygons ...
IMHO, except for extreme close ups, a good 3D fill and a good texture do the job quite well.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
HI Mark
Thanks for you help, but what im looking for is the real construction layers like the metal sheets, metal frames, insulations, structure, blocks, and then finishes, hope you know what i mean ihihihihi thanks.
lovetrain
Hi Mark
I wonder if you can post for me the detail drawing of the metal cladding that you did? thanks
This is one of the details from that project. The metal cladding was horizontal and a square profile. This dosent sound like what you are looking for.
Aussie John
in detail section I use a custom made line to show the metal deck profile
Cheers John
[/size]
