Project data & BIM
Missing Archive button in Change Manager
Scott Bulmer
Greetings, not sure what I am missing but I desire to move published changes into the archive folder in change manager. There is no archive button in the pallet or context menu as noted in the manual. Thank you, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
Can you show a screenshot of this?
Is this a Solo or Teamwork Project?
Erwin Edel
Think you can archive through menu: Document > Change Manager
You should see the Active Changes, select one and click the little folder with a change cloud coming out of it to archive it.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
