Project data & BIM
Mistakes at the calculation of the layers wall volume.
Why?
Why?
[img]http://www.ac9.<b>[censored]</b>.ru/hi.gif[/img]
Could you be more specific?
I believe he means that that the volumes of the various skins of the upper
wall are incorrectly calculated: out of the 4 skins, 3 should be the same as in
the case of the lower Wall, because the Column cuts into only one skin.
That one skin should have a smaller volume, all 3 other skins should have
the same as in case of the other Wall.
It is probably a bug.
