2019-05-24 08:42 AM - last edited on 2023-05-30 12:35 PM by Rubia Torres
2019-05-24 09:42 AM
2019-05-27 02:47 AM
2019-05-27 03:03 AM
jake_h03 wrote:The only options I know of when publishing MOD files are those in the attached image.
Hi Barry,
I am not saving selection as module or 'save as' the whole file as a mod type.
I have saved views that I am exporting as a mod from the publisher.
I have done it this way for years and it has always only exported the layers that are turned on in the saved view being published. To confirm, I just started a new file and tested this and it worked as normal. For some reason the other file I'm in is working differently. I can only assume its a setting somewhere
2019-05-27 03:16 AM
2019-05-28 04:46 AM
2019-05-28 06:09 AM
