‎2005-07-05
11:02 PM
‎2023-05-30
01:03 PM
Rubia Torres
‎2005-07-05 11:11 PM
‎2005-07-05 11:39 PM
‎2005-07-06 01:41 AM
Tom wrote:In my experience modules have only ever contained the used attributes. I have never heard of modules carrying layer combination attributes.
I have selected several drawing elements and saved them as a module. When I open the module, I see have all the layers, layer combinations, etc. of the drawing I saved it out of.
Is there I way I can save a stripped down version of that module that will have only the layers of the elements that I saved, and the layer combination that was used at the time?
That way when I insert it into a different drawing, it won't bring all the extra layers with it.
‎2005-07-06 01:42 AM
‎2005-07-06 03:45 PM
‎2005-07-06 04:10 PM
When I say "open" I open the module drawing just like a typical .pln drawing. I need to make a few adjustments to the module, then save it again as a .mod file. Maybe that's where all the extra layers are coming from. If so, then all those layers show up on the drawing (.pln) that I merge the module into.Tom
Do I need some kind of default empty file to open the .mod file to work on it.....or something like that?
I know for sure that the items I selected to create the module had no more than 5 layers, yet when I open the .mod file (see above) there's a bunch of layers that were on the original drawing.
‎2005-07-06 04:35 PM
‎2005-07-06 04:50 PM
‎2005-12-14 12:08 AM
