gdford
Modules not honoring solid element operations
I have published a .mod model and the interior walls that have been trimmed to the roof via a solid element operation are sticking out of the roof when i open or hotlink in the module??
Seriously?
Is suppose to happen?
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
Is the roof part of the hotlink Module?
If the roof is in the original hotlink module, I would expect the walls to remain trimmed, even when you hotlink it, so long as the walls and roof are part of the module.
If the roof is in the main file, sure you can trim the hotlink walls to it, but when you open the hotlink file the walls will not be trimmed.
