Multiple network licenses being used
It seems that when running version 14 with any other version at the same time two network licenses are being used.
Running any combination of versions other than 14 (i.e. 10 & 11 & 12) at the same time results in only one license being used.
Is there any way to run 14 and another version together but to only use one license?
This is not a problem if you have a stand-alone key.
11 Replies 11
OK, so this means my information was half true.
Actually, it was just way outdated.
Hello,
In our office having ArchiCAD 11 and 13 open will use two network WibuKey licenses
gkmethy wrote:
ArchiCAD 8-13 will also use the same license
Regards, Juha
