muzedesigns
My model has disappeared from the 3D Window!
Hello everyone!
My model has now quite complex and I am sure has reached quite a glutenous fie size..
Over the last 2 days whilst working on the project, any sought of 3D View in the 3D Window disappears – (and not from moving the cameras to some ridiculous view point).. The only way to recover it is to reopen the back up plan and go back a few minutes/hours/ work depending when I last save and hoping that I haven’t saved over the back up.. Is this a prevalent problem or just a program with the user and not the software.. it is quite disconcerting and plenty frustrating!
Any ideas or suggestions that you may have?
Would love to hear your thoughts, as per usual - if you get the chance or if this topic is relevant to you at all!
Chrissy
Chrissy Avramidis
|| ArchiCAD Versions 7-22 ||
|| 27inch iMac Pro (2017) | macOS High Sierra 10.13.6 | Processor 3 GHz Xeon W | Memory 64GB 2666 MHz DDR4 | Graphics Radeon Pro Vega 64 16368 MB||
21 Replies 21
There are many things that can cause this, here is a list:
https://community.graphisoft.com/t5/Design-forum/Walls-in-schedule-but-not-in-model/m-p/225570/highl...
2raarchitecture
Thank you!
2RA Building Workshop
www.2rabldgworkshop.com
11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz. 16.0 GB. NVIDIA GeForce RTX 3060 Laptop GPU.
ArchiCAD 25. 5002 USA Full
