Project data & BIM
Need help with expression
Mats Knutsson
I want to add an automatic property to doors depending on which zone the open into. All is fine when the door opens into a zone but when there is no zone (exterior doors) the "to zone" gives <Undefined> and I'd like to change that to "Ext door" or something else but I can't figure out how to do this?
Anyone smarter?
/Mats
IFS
CONTAINS (To Zone}; "A" ); "Type 1";
CONTAINS (To Zone}; "B" ); "Type 2";
CONTAINS (To Zone}; "C" ); "Type 3";
CONTAINS (To Zone}; "D" ); "Type 4"
Xandros
Hi, you could try:
IFS(
CONTAINS (To Zone}; "D" ); "Type 4";
To Zone="";"Ext door")
or maybe this
IFS(
TRUE; "Ext door"
 Hope this works out
ArchiCAD 27 GER / Win10
Intel i9-9900K / 64GB RAM / nVidia GeForce RTX 2080 Ti
Nope didn't get it to work.
I can use ISUNDEFINED to give undefined a vale but can't seem to use it in my IFS sequence nor using it before the IFS.
Mats Knutsson
I think I managed...by nesting the IFS into the IF... IF only I could be faster with these expressions...
IF (
ISUNDEFINED(To Zone);
"EXT";
IFS (
CONTAINS(To Zone; "SOV");
"mjuk och fin";
CONTAINS(To Zone; "HALL");
"halltröskel";
CONTAINS(To Zone; "WC");
"das tröskel";
CONTAINS(To Zone; "KÖK");
"köttig tröskel"
Setup info provided by author
