Project data & BIM
New problem moving drawings in Archicad 13, hotfix 3600
Help! After installing hotfix 3600 for Archicad 13, I can no longer move drawings in layouts. Need help. Also can not access drawings already placed in layouts.
Hi Don,
Don't panic - check you haven't got grid snap turned on in the layouts. The keyboard shortcut is S and is easily pressed by accident.
Hope that sorts your problem!
Yes, thank you very much. I discovered the problem myself also by turning the tracker on full time. But your answer is exactly correct.
