Project data & BIM
New user, Zones?
I'm trying to set up zones to label our school project. The problem is that whenever I make a zone, the stamps don't show up in the 2D working area. How do I fix this?
4 REPLIES 4
Erika Epstein
You need to have the Model View Option (MVO) saved with the view set to show the zone stamp.
Document > Model View Option >Override Fill Display tab
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
It says that Zones are enabled, the hide zones box is not checked, but they're not showing.
Erika Epstein
Jonathan,
See the attached.Check that the View has both the MVO and the layer you have the zones on set to show. If this doesn't resolve the problem,
post a screen shot of your settings.
Please add to your signature which OS you are on and version(s) of Archicad you are using.
HTH
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Erika
I know what you mean, but someone else might not be able to read your screen shot.
Might want to up the res or size a bit?
Bier
