how can I create Template file
Hi Friends,
How can I use my default modified short cut options template. I have created shortcut options and save it as template format, when I was use this it is worked well. but some times I should remove this archicad softwatre and reinstall on my PC at that time again I need to create template file, is there any option to use my old shortcuts keys created template file. I am trying to use this template file when i was open the archicad file, but this is not working. please tell is there we need to change any options.
Thanks for your help.
Nagesh
If you mean that you created Keyboard Shortcut schemes in the Work Environment Dialog, then in the Shortcut Schemes page of the Dialog you have the Export button. Export the Scheme, put it on the other computer and there use the Import button of the same Page. Then the Keyboard shortcuts will be transferred.
