2022-09-14
06:11 AM
2022-10-04
02:17 PM
Oleksandra Vakariuk
I want to make a new transmittal showing only the amended layout
The problem is that I haven't done an issue before. I had to create a first issue 01 with all the layout including the layout containing the changes.
When I tried to create the second issue showing only the layouts with the changes , t the transmittal doesn't let me add this layouts because there were already in the issue 01. TI looked into all tutorials and Graphisoft community but I couldn't solve it. Thanks
Solved! Go to Solution.
2022-09-14 08:16 AM
I’m not sure I fully understand what you are trying to do but you can force any layout in to a transmittal even if it has no revision just by using the add layout button. If you need the revision letter to increase you can manually create a revision that’s not linked to any elements and force add it to the layout.
2022-09-14 08:16 AM
