Project data & BIM
OK buttons gone AWOL!
David Collins
I've loaded ArchiCAD onto my portable and have just noticed that the "cancel" and "Ok" buttons are missing from some menus, such as the layers and materials menus. Everything thing else seems perfectly functional.
Has anybody ever seen this one before? Any clues how to get them back?
I would just reload ArchiCAD, but the installation disk and I are now on opposite sides of the world.
David Collins
Win10 64bit Intel i7 6700 3.40 Ghz, 32 Gb RAM, GeForce RTX 3070
AC 27.0 (4001 INT FULL)
4 REPLIES 4
Perhaps the windows are too big and they are below the bottom of the screen?
You can always use ctrl + . (period/full stop) for cancel and enter for OK in the dialogs.
Djordje
Increase the screen res if possible?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
David Maudlin
David:
You could also try applying a different Palette Scheme under the Work Environment.
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Collins
I can see the entire popup menu, but the OK button is still on vacation. Just hitting enter does the trick. I was so astonished to lose the button, I don't think that obvious solution would ever have occurred to me.
Many thanks, ArchiBrothers.
David Collins
