One - Click install
I have managed to get most of the installation process down to clicking on one .bat file. It will install AC for me, then the update, then copy the updated libraries over for me. The part I am stuck on is getting the IP address, WkLAN, to be automatic as well. I am guessing that it is in the registry somewhere? Anybody tried this at all?
Simple .reg file will do that for you, I think.
In XP keys can be found:
HKEY_CURRENT_USER\Software\WIBU-SYSTEMS\WIBU-KEY\Network\03.00\WkLanAccess
HKEY_LOCAL_MACHINE\SOFTWARE\WIBU-SYSTEMS\WIBU-KEY\Network\03.00\WkLanAccess
Name of the key can be whatever
Value for the key is IP address or name of the wibu server machine.
Wibu can use two "modes" in client computers:user and machine specific
Set those both first manually and view registry to see correct keys.
When or if different user logs in the client computer, then "machine" one is quite usefull, in order to run ArchiCAD.
Set timeout/release value in server something smaller than default 1140
/Petri
Thank you!! That looks like what i needed to know. I was looking under the local and not the current.
