2005-11-30 05:02 PM - last edited on 2023-05-30 01:02 PM by Rubia Torres
2005-11-30 05:49 PM
2005-12-01 12:03 PM
2005-12-01 01:53 PM
2005-12-01 06:04 PM
Thomas wrote:Ah, well actually I
your answer gave me the idea that it may be permanently tied to the currently used zone boundary walls in some way that blocks additional zones. That would mean that you can't re-use an already used boundary wall for a second zone (at least not on the same side of the boundary) and that would explain why it doesn't work for me. (maybe it's just my too predictable brain that tries to find some logic).
2005-12-02 12:04 AM
Rakela wrote:Well, no computer could ever guess how I want my subdivisions...
thomas, nothing to do with your problem, but sounds like you also need
a zone where you can just type the sf required by the new tenant and the zone stretch by itself to a direccion set also by you...also good for lot subdivisions.
2005-12-02 08:53 AM
Thomas wrote:Auto updating area calcs are possible within the zone stamp GDL by using the ROOM_AREA parameter instead of the usual ROOM_CALC_AREA parameter which require the "Update Zones" command. The update isn't live as you stretch but it is instantly updated.
But some 15 years ago, I had a Norwegian CAD package called Jonathan. (Slow as mud, no wonder it never took off, we used it on the original MacII...) It had one feature I've actually never seen since then. You could draw a shape (a fill), have it display the area, and then move a corner or a boundary while the area figure updated itself continously in real-time on screen!
2005-12-02 11:18 AM
2005-12-04 07:17 PM
Thomas wrote:It should warn you that you are placing a zone within an existing one, and ask you whether you want to do so.
Matthew,
thanks for your tip. I'm not very familiar with the calculation tools and zone parameters, sothis is an area where I haev work ahead of me.
But back to the subject. What do you think about the equality issue? Why does my Archicad refuse to place a zone within an existing one, while James' doesn't? What am i doing wrong?
2005-12-05 05:14 AM
