2009-09-01 07:19 AM - last edited on 2023-05-26 09:01 AM by Rubia Torres
2009-09-01 08:41 AM
2009-09-01 08:47 AM
berus26 wrote:There could be many things I would recommend taking a look at the layer combinations but probably more importantly make sure all of the story heights are correct as well as the cut plane settings.
I AM CURRENTLY USING ARCHICAD 12 IN OUR OFFICE AND IM WORKING ON A 15-STOREY MIXED-USE BUILDING.WHAT I DID IS I CREATED EACH FLOORS ON SEPARATE FILES THEN WHEN I FINISH STACK THEM ALL ON A SINGLE FILE USING HOTLINK.I THINK THE IDEA IS SIMPLE, BUT I LEARNED THAT THE HOTLINKED FILES DOES NOT APPEAR EXACTLY THE WAY THEY SHOULD BE; SOME WALLS ARE OUT OF PLACE AND OVERLAPPING.IN SHORT THE PLANS I ATTACHED DOES NOT LOOK THE SAME WHEN I OPEN THEIR MOTHER FILES.I WANT TO KNOW HOW TO FIX THIS PROBLEM OR IF EVER I DID SOMETHING WRONG I WANT TO KNOW WHAT IT IS.I HOPE SOMEONE OUT THER COULD HELP ME.THANKS IN ADVANCE!!!
