2008-03-10 06:28 PM - last edited on 2023-05-26 09:03 AM by Rubia Torres
2008-03-10 06:57 PM
Laura wrote:I had what seems to be a similiar problem with module height and had to set it to a negative height on the First Story to get it to appear correctly. Apparently it's a bug due to the difference is american first floors v. european first floor (american second floor) Ignacio explained it here:
The second problem is recent: after hotlinking one of these MODs, and specifying that the First Story of the MOD is to be placed on the First Story of the host, the MOD appears placed on the story above (walls set to "Show on Home Story Only" aren't visible on the First Story, and when viewed in 3D, the walls are set with their base elevation at 13'-4" above Current Story). By setting the Elevation of the MOD to -13'-4", it appears as needed but again, there is something wrong here.
It seems we are able to work around these issues, but after searching the forum, and not coming across anyone experiencing the same problems, I'm curious if we are the only ones?
2008-03-10 07:02 PM
Chris wrote:Ahh -- I am familiar with the difference between USA First Story = 1 and [all others] First Story = 0 -- this makes sense -- thanks!
2008-04-17 11:47 PM
