‎2006-05-23
06:12 PM
‎2025-01-31
03:20 PM
Molinda Prey
‎2006-05-23 06:20 PM
‎2006-05-23 06:45 PM
‎2006-05-23 07:16 PM
tsturm wrote:Most of the projects were duplexes or flat/townhouse combinations.
Tom
I have done this type of referencing in an apartment complex. But we are doing a housing complex of 12 separate duplexes. The Units are joined in different fashions so that the roofs and elevations are unigue in every case.
‎2006-05-24 01:43 PM
TomWaltz wrote:If the details are not in a separate file, then how do you handle getting them into each PLN file for the production set?
The details are not really in a separate file. They are in the same file as the units.
Like I said, anything that repeats goes in with the units. That may mean that that MODs only contain the interiors of the units and a couple exterior walls with windows or porches.
‎2006-05-24 04:11 PM
tsturm wrote:They are never copied into each PLN. They are just placed into the LBK.
If you are copying them in, then what happens to the links for the detail windows? Do you then just use the detail marker to mark the locations and there is no true detail cut anywhere? I suppose that once you figure it out then there would be no need to have the actual model location to work again from.Since the company does so many of this type of projects, very few new details are cut from the model. Most are from the office detail library
When you are using MODs, are you really saving them out as .MOD files or just using the attach drawing feature like a XREF?The units, with their appropriate layer combinations, are saved as View Sets and published to MOD en masse. Like I said before, this allows you to make several exterior layers that all wrap around the same interior. You can also dimension, note, and cut interior elevations from the original units and just turn those layers off before you publish to MOD.
‎2006-05-24 04:46 PM
‎2006-05-24 05:02 PM
TomWaltz wrote:This explains why you do not copy the details into the project PLN and you have to hand type the detail numbers. Your details are coming from a central location outside of the projects. A Office Detail Library.tsturm wrote:They are never copied into each PLN. They are just placed into the LBK.
TomWaltz wrote:Could you draw a diagram of the process to show how you are using the different exteriors with the different interiors and where everything lines back up to create building sections and exterior elevations.
‎2006-05-24 05:30 PM
tsturm wrote:Nope. It's just a really good "unit" template that is pre-stocked with details. It's all in the same PLN as the Unit Plans are.
Could you draw a diagram of the process to show how you are using the different exteriors with the different interiors and where everything lines back up to create building sections and exterior elevations.There is no "interior/exterior" division. There are either
I get the sense your projects are broken up into Shells and Interiors. Then you are just putting different interiors into different shells.
‎2006-05-25 02:04 PM
TomWaltz wrote:So the details in this Master PLN are all linked to the drawings, but none are actually cuts of the model, correct?
TomWaltz wrote:Do you MOD in the Houses to this Master PLN? Still not grasping how you are dealing with the exterior versus interior and the upgrade options on the houses. I think I get the part about options like porches, patios as additional MOD to the base house. But how about the House itself. Are you using different plans with the same shell?
(1) MODs placed for the parts that are typical, which are usually a combination of interior and exterior
(2) elements like roofs and foundatons that are not typical and are drawn/modeled "in place" in each house
