The message you are trying to access is permanently deleted.
2018-07-29
02:46 AM
2025-07-13
06:58 PM
2021-01-20 07:04 AM
2021-03-18 05:49 PM
2021-07-19 11:46 AM
2022-10-11 07:34 PM
Is there a fix for this issue? More than 4 years later and Graphisoft couldn't find the solution? Or didn't even bother to look for one?
2023-04-25 10:33 AM
2023 here and I have the same issue.
Occurs on my home PC only.
Makes it almost impossible to edit properties.
Would love for there to be a fix.
2023-04-25 04:42 PM
Thanks for the feedback, and yes we're aware of this issue for some users.
We have been (and are) looking at different solutions to this. Unfortunately we can't really fix it directly inside the existing UI control that we are using here - due to some technical limitations. But we are still investigating it, to find a solution.
2024-09-04 11:34 PM
Has this issue been resolved? We just ran into the same issue. Only in the expression editor box does this font pop up. Everywhere else, the fonts show up correctly.
2024-09-05 11:27 PM - edited 2024-09-05 11:27 PM
Which Archicad version?
Also, are you using the latest hotfix/update?
