Tom Krowka
RCP lineweight
Is there any way to change the lineweight (color) on the reflected ceiling plan viewset. I would like to change the walls to a lighter pen weight. However, if I change it in the RCP viewset, it will change in the floor plan viewset, right?
Ideally, I'd like the background for the RCP to be like the ghost layer. Any way to incorporate that idea into the scheme?
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
Link
You can do this in PlotMaker, just like mapping pen colors.
Link.
Tom,
I usually the pens from the 2nd line on the pen color chart for my RCP's. When I get to plotmaker I check to set everything else to .10mm line weight except for those. So the key is to use different pens and then assign the line thicknesses in plotmaker.
Mark Gillis
architect
Asheville NC
