Karl Barker
Rebuilding Sections and elevations
Argh!!!!!!!!!!!!!!!!!!!!!!!!javascript:emoticon(':evil:')
In previous incarnations of ArchiCAD, there was a command that I used on a daily basis as a minimum.
"Rebuild selected sections and elevations"
It appears that this filtered command has gone.
Why?
How then can I rebuild the four main sections from my drawing (all live) but not the detailed section (still live) that ahd fils and other things on them with different layer combinations?
It used to be that i would set on th eplan the layercomination of the elevations/sections that I wanted to rebuild, select thos particular section/elevation lines and rebuild only those ones.
I caannot see in the work environment when viewing all commands in the toolbar alphabetically where that command has gone.
I am stcuk with rebuilding all modle sections, all drawingh sections etc.
Well ALL of my sections are modle sections.
Any clues?
Karl.
Karl Barker.
27" Macbook Pro, M4 Max
48 Gig Ram
Mac OSX 26
AC 5.5 - AC29 (NZE)
6 Replies 6
TomWaltz
It's still there, just not in your Work space apparently. You should be able to get it through the Work Environment editor.
Tom Waltz
__archiben
it's not! that's exactly what i thought and had even drafted a post similar to yours . . . except when i went looking for it for the screenshot i couldn't find it anywhere.
all of the rebuild commands are there except for the 'rebuild SELECTED...' commands.
~/archiben
b e n _ f r o s t
TomWaltz
I'm not at my office now so I can't screenshot it, but I added it to our standard workspace. I know it's there! (unless I totally messed up and put in something else)
Tom Waltz
__archiben
right you are! let me know where to find it . . . here it is in AC10 -->
b e n _ f r o s t
Karl Barker
I have even tried importing my custom profile from AC10 into AC11.
The command in question was removed in the translation.
Karl Barker.
48 Gig Ram
Mac OSX 26
AC 5.5 - AC29 (NZE)
Bruce
Yes - frustrating that...
It seems Graphisoft has shuffled around the commands from AC10 to AC11 - I had to rebuild my workspace to get my favourites back.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
