Reflected ceiling plan
Morning All,
Just wondering how to go about setting up reflected ceiling plans.
Using a single storey dwelling as an example, should I set up the ceiling plan on the same storey as the ground floor plan and customise the view using layer combinations? Or should I set up the reflected ceiling plan on its own storey.
Much appreciated
3 Replies 3
Bruce
Typically do it on the same storey - otherwise you have a real headache trying to get the walls and openings show.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Thanks for your response Bruce, that makes sense.
What about a roof plan. Would it be best to set it up on its own storey? How high should the floor plan cut plane be for a roof plan?
Thanks
Bruce
Yes - roofs should be on their own storey. Generally you see the entire roof, so the cut plane would generally be higher than the ridge...but given ArchiCAD's symbolic display, you probably won't need to adjust this for the majority of situations.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
