2005-09-22
		04:11 AM
		2023-05-26
		09:06 AM
			Rubia Torres
2005-09-22 04:24 AM
James wrote:That would be nice, but I've not come up with a way to pull it off yet...
I have over 2,700 modules placed (with still about 1,500 to go). Now I want to replace some of those with another module.
I know I can replace ALL modules, but I want to replace only the selected modules with another module. Anyone know a way to do it?
2005-09-22 04:32 AM
TomWaltz wrote:Hey Tom.
2005-09-23 08:40 AM
2005-09-23 11:46 AM
James wrote:Is it necessary that the Modules are Modules?
I think I've found the limit of Archicad modules.
2005-09-23 12:01 PM
Djordje wrote:No, they don't have to be modules. After I did the 50min update of the modules I could do a 3D view with no crashing so that was good.
Can they be Objects?
2005-09-23 12:10 PM
James wrote:The Modules are OK if you need a constant live update.
James wrote:Not really ... the same model that you work on as PLA or MOD, can be saved from the top 3D view as an object. Make sure to get rid of the internal stuff. Updating is also very straightforward - just re-save the object. Make sure, of course, that the insertion points are the same ...
In hindsight, doing objects to start with would have been better. Would have taken longer at the start, but would have SAVED time in the end.
2005-09-23 12:30 PM
Djordje wrote:I've done a fair bit of object coding in the past. And knowing me I would have wanted to have coded it from scratch so everything is parametric and clean. and use presets in the object for different arrangements. And of course integrate hotlines etc.
Been there, done that - guess who I know that objects work better😉
Oh, just to annoy you a bit - did you try it on a PC?😉
2005-09-23 08:01 PM
2005-09-24 01:42 AM
Karl wrote:Hey Karl,
If you can't say 100% yes for each of these for a module, then - when there are thousands - it should be an object IMHO. Objects are also live-linked and easily replaced/updated (if the source elements are kept). If the elements in the "module" object are simply a collection of elements in plan - on a single story. Then, no 3D magic is required. Just select the elements, GDL Menu, save selection as object. Done. When more than one story, sure, the 3D top view thing is required.
Tell us more...
