Project data & BIM
!Restored: Probelms with the Grid Tool
Just a heads up to everyone. So far I know of two rather big problems with the grid tool in AC11 that will cause the program to crash in a section and elevation window.
1. If the grid elements are locked or are on a locked layer when opening a section or elevation Archicad will crash
2. If you place a section marker in an elevation or section window then attempt to modify it, archicad will crash.
From what I understand Graphisoft is aware of these issues and they are working on it, but for now the only solution is to remove the grid tool from your project.
13 REPLIES 13
Rod Jurich
Scott wrote:
Does anyone have any idea why this is happening?/......My Grid Settings DB has never looked like that shown in the manual. /.....All thoughts are welcome.
Scott you need to open your WE and check each box to enable the tool.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Stress Co_
Scott:
You can also enable the Grid tool panel in the Section and Elevation tools.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Stress Co_
P.S.
I think Rod's post shows settings for the Info box... you maybe wanted the Dialog box?
Scott Bulmer
Stress Co & Rod,
Thank you so much for the clarification. Visibility of certain Tool Dialog Box items were limited in the WE as you pointed out. I guess AC can get in a funky state every so often, kind of what I'm in today. Perhaps a mountain bike ride would be helpful.
S
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
