Revision History Panel
I would like to change this 'Not in Transmittal Set' into 'Granskningshandling' like it is on the other stamp. I don't see how can I do that in the revision history. Thank you so much
1 Solution
I think the "Not in Transmittal Set" text does not come from the Revision History library part. On your screenshot, I think the Revision History object starts above the "PROJEKT NR." field.
If you go to the Master Layout of this Layout you are showing, select the Text. I suspect that it is an Autotext or a static Text.
Go to post
Thank you!
