2005-03-13
		04:13 PM
		2023-05-30
		01:04 PM
			Rubia Torres
2005-03-14 02:00 AM
Tom wrote:Hi Tom,
What is the difference between rebuild from model, and keeping the autorebuild on in the section settings. If I rebuild from the model, I don't get the same layer settings on as I do if I keep on the autorebuild.
Does the rebuild from model take the model view settings when it redraws it?
2005-03-14 03:38 PM
then you will get the same layer settings every time.The plan view and the section view have different layer combos, and display options. When I click on the section in the plan view, which layer combos and display options will it take? In the case of this question, I am not using the view editior. but opening the section from a saved view set.
2005-03-14 05:42 PM
2005-03-14 07:12 PM
2005-03-14 07:47 PM
Tom wrote:Tom... please
Yes it does......thanks. I guess I have to use the view editor, and can't go directly from the marker to the view set.
2005-03-14 07:59 PM
