Project data & BIM
Schedule - Bold fonts
sknsnw9
So I have something weird going on that I can't seem to figure out. It's happening to all of my schedules. I have all of the headers set in Bold font, but once I click out of the cell the Bold font disappears and it goes back to regular font. Is there a setting that's overriding it or something that I might've over looked?
Operating system used: Windows 10
Archicad Solo 24 - 28 : Windows 10 Pro 64-bit : 16 GB ram / Intel Core i7-4770k @ 3.50GHz : NVIDIA GeForce RTX 3060 / MacBook Pro M3 Max
There may be other fonts within the family of "Stylus BT", that handle the bold status instead. When you open the font selector, are there multiple options under or next to Stylus BT?
James Badcock
Graphisoft Senior Product Manager
5 REPLIES 5
sknsnw9
Here's some pictures for reference.
James Badcock
Stylus BT is a single typeface font style.  If you want to use bold charecters then you need to choose a font that has several different typefaces within the parent font name.  Hope this helps.
Project Manager
Rutledge Maul Architects, PS Inc., Seattle, WA
Windows 11 Pro, HP Pavilion Gaming Desktop 790, Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz 3.19 GHz, 32.0 GB RAM, 64-bit operating system.
Archicad 28 - Graphisoft Forward
Ditto above... and that you might want to replace Stylus BT with a newer font such as Tekton Pro which is similar  ... if it is available to you (installed along with dozens of others with Adobe apps).  It's based on the earlier Tekton...
https://fonts.adobe.com/fonts/tekton
One of the forum moderators
Ah yes, that's the issue. I thought I had it working before, but it must have been a different font and never noticed it till now. Thanks for pointing that out!
Setup info provided by author
