Guru
Schedules: Override Field Value
Hi all,
Is there a way to override a field?
Primarily the case is where a field may give a NUL return, I am wanting the possibility of inserting a non-uniform custom value.
Ling.
3 Replies 3
James B
The ability to customise 0 value display in Schedules was introduced in AC29.
https://help.graphisoft.com/AC/29/INT/index.htm#t=_AC29_Help%2F005_NewFeatures%2F005_NewFeatures-20....
James Badcock
Guru
I am wanting more than just a uniform replacement, and the value is sometimes NUL instead of zero.
Ling.
James B
This new option is not for the whole Schedule, but can be set separately per field. One field 0 and another as NUL.
James Badcock
