Nic Tulban
Scheduling hotlinks
is there a way to get a schedule with data from the hotlinks in the project - name, design option, number of instances and so on - but limited to the niveau of the hotlink, not deeper (not refering the contained entities)?
Any Idea is useful!
Lot of thanks,
Nic
2 Replies 2
You should be able to set the schedule criteria to look only at a specific hotlink or hotlinks.
If I understand this currently, you want to schedule the Hotlinks themselves as items, not elements located in Hotlinks.
Archicad does not offer such capability.
And unfortunately, I cannot even offer any workaround. The only data you can get about Hotlinks in a schedule is the Hotlink Master ID, but not their Name, the Design Option they use, of how many instances of a Hotlinked Module are placed.
