2005-08-01 07:24 PM - last edited on 2023-05-30 01:14 PM by Rubia Torres
2005-08-02 04:13 AM
2005-08-02 04:21 AM
2005-08-02 08:09 AM
Weston wrote:the little 'magnet' is the quick-select toggle - and it's worth reading the various new selection methods in the manual if you are making the big jump from 6.5 to 9.
also, check the options on the tool pallette for the arrow tool. see the little magnet? turn that off, and the arrow functions like it always has (that i can remember) - turn it on and you can pick any object with a fill just by clicking inside it. makes it easy to grab text!
2005-08-02 12:45 PM
2005-08-02 02:12 PM
2005-08-02 04:03 PM
2005-08-02 04:15 PM
2005-08-02 07:50 PM
Mark wrote:It is easiest to select the fill with the "Magnet" on (Depressed)
Not sure what you mean by 'swiping' but there are a number of ways you can select things that hopefully might answer your question.
3. Select the fill and draw a selection rectangle over the line. Fill will be deselected, line will be selected. This is more useful when you have to select a lot of elements except one.
Hope that helps.
2005-08-31 02:07 AM
