Project data & BIM
Setting UP Deffault settings or template??
Hi Everyone,
Is there any way to set my own font for every textual element, by default, when I open Archicad and new project to be always same font as I want, same size, etc.. instead of default Arial font.
Also, Is there option to save already set up annotation elements, liike marker size, shape, position, style, dimension line, style, and every 2d elements into some kind of template. Also, can I set up my pen set, materials, atributes, etc.. for every of my projects into some kind of atributes??
I'm not fan of actual colorful style of archicad elements, so I want to make my own style?
Best regards!
1 REPLY 1
Guru
Always start your projects from a pln or tpl file that you have already modified these things within each tool.
Ling.
