ā2021-11-03
06:54 PM
ā2022-10-04
01:14 PM
Oleksandra Vakariuk
Hello, I am excited to see that you can now view zones in section and elevations in Archicad 25. This feature prompted me to download this version and transfer from 24. But when I open a file, I cannot figure out how to display a zone in Section. Is there a toggle I'm missing to display that information? In the graphisoft overview it went into a lot of detail about the new zone tag but the zones aren't visible in section to tag.
ā
Floor Plan showing Zones
Section not showing Zones
ā
Solved! Go to Solution.
ā2021-11-05 06:14 AM
Great pity that the Zone stamp doesn't link directly to a Surface. It means we have to manually link the colour on the floorplan to the surface in section, elevation and 3D
ā
ā2021-11-06 10:33 AM - edited ā2021-11-06 10:35 PM
So zones in sections/elevations are solid blocks. If I want to see my project I must make a Graphic Override Combination to make them transparent. But I don't always want glass to be transparent.
Half baked solution.
ā2021-11-08 01:51 AM
I think the best solution if you want to keep the glass in windows as solid (not transparent) is to wire frame the zone layer in the elevations as @James Murray suggested and use a Graphic Override to hide the contours.
Or hide the zone layer completely as @reidweber suggested - just be sure to turn off the option in the label to hide with associated elements.
Just when you need to add labels, be sure to change to a layer combination that shows the zones as solid.
ā2021-11-08 07:18 PM
Thanks Barry, these workarounds do works. But they mess with our layers standards.
I think we have to stand loud that those workaround are not the best practices. Perhaps Graphisoft listen us.
ā2021-11-09 11:43 AM
If you create Surfaces to match the Zone Stamp colour and match these surfaces to each Zone stamp then everything works because these Surface can have transparency without a GO.
ā
ā2021-11-09 03:37 PM - edited ā2021-11-09 03:46 PM
Yes, but this only works with transparency turned on in Section Settings. This option affects all the glasses, and maybe I don`t want them to be also transparent. That is the point.
ā2021-11-09 11:44 PM
Zones in Section don't have to be solid and glass can be solid if required.
ā
ā2021-11-10 12:17 AM - edited ā2021-11-10 12:19 AM
What settings do you have applied to your zone surfaces to create the transparent zones and opaque glass?
ā2021-11-10 12:58 AM
I have a series of Surfaces which match the Zone Category colours. I use them for both the Section and 3D views. These Surfaces are semi transparent and the Sections have transparency on. I have introduced an additional GO rule which changes the Glass Surface to white (to remove the transparency). I use the Zone surfaces as shown because I think its a waste of time to to just show Zones in 3D as Glass especially when creating a Massing Study.
Hope this helps.
ā2021-11-10 05:16 PM
I don't have a checkbox under Project Preferences>Legacy to uncheck. I'm using Archicad 25 3002 USA FULL
