Strange Mods
Can anyone explain why Archicad does what it does with mod files...
1. Adds all the layers from the main file you inserted the mod file into.
This happens for all mod files once inserted into a drawing. Very annoying as I like to work with a limited layer subset.
2. Why updating the mod file in your main drawing resets your home view to the mod file's home view. This only happens with some mod file. Sometimes even the mod file shifts
Are the above known bugs?
Regards
Maurice
Archicad 2018 Aus Full
Win XP Pro, P4 2.8 ghz 1.5 gb ram
5 Replies 5
I am led to believe by my reseller that the movement of mod files is a matter that is currently being attended to by Graphisoft. Apparently this bug appeared in build 2018 but was't present in the previous released build. The movement of mod files has soemthing to do with their distance from the origin.
Ben Odonnell
Mike,
You are right about the shifting of mods. It is a know bug is is being addressed at the moment.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Miquel Garcia
Mike:
Create a mod file with a limited subset of layers of the main file is an old wish, that I have desired many time ago. The only workaround that I have found is to save not as a module but as a clipboard module by definig a layer combination that contains the desired subset of layers, selecting all with the marquee and copying before saving it. An annoying method, of course, but it works.
Another wish concerning modules would be the ability to show only part of a placed module, by defining a polygon that works as a 'mask', showing the external or the internal area. I think that it would be very useful.
Regards
Miquel
Capella & Garcia Arquitectura
AC18 - AC21, iMac 27" 3.1 Ghz Intel Core i7, 16GB Ram, OSX 10.13.1
Thanks for the response guys. Lets hope a fix arrives soon.
Like the idea of clipping mods - also xrefs would be great
Clipping a module - YES PLEASE!
