2010-07-20 10:15 AM - last edited Tuesday by Molinda Prey
2010-07-20 01:27 PM
2010-08-02 05:44 PM
laszlonagy wrote:Thanks. My problematic zones have the above charactristics. They just don't update when I modify them !!!??
If it is an automatically updating Zone than it must be surrounded by elements that are all Zone Boundaries.
The Reference Point of the Zone must be within those boundaries.
The Reference Point is marked with a small + sign.
2010-08-02 05:57 PM
2010-08-04 10:53 AM
laszlonagy wrote:It's the same. But I found out that you have to choose a particular type of zone so that it updates automatically - in my version AC11 Fr - n°20 zone jour 02. All other types have to update by selecting them and update manually ...
What happens if you recreate the Zone from scratch?
Maybe there is something wrong with that zone instance.
2010-08-04 11:02 AM
2010-08-25 04:37 AM
2010-08-25 08:36 PM
2010-08-26 12:42 AM
2010-08-26 04:11 AM
snapcrackle wrote:You can change the type of zone once you have placed it.
Masterscript,
You are right, "Update Zones" command is the correct syntax for a zone "recalculation".
I would really like it if the zone command could be used to quickly set a zone based on reference lines, but then arbitrarily alter the boundaries. What happens currently is that the "Update Zones" will reset itself to the reference lines, so your only option is to create a custom zone to start with.
Snap
