Surface zone doesn't update
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2010-07-20
10:15 AM
‎2024-12-31
02:49 PM
Molinda Prey
A little technical problem which can be really annoying. Can anyone shed some light on it? I've searched longtime with no solution yet. I've once copied an automatic updating zone and paste on my projet, it turned out the same problem...
Thanks a lot.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-07-20 01:27 PM
The Reference Point of the Zone must be within those boundaries.
The Reference Point is marked with a small + sign.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-08-02 05:44 PM
laszlonagy wrote:Thanks. My problematic zones have the above charactristics. They just don't update when I modify them !!!??
If it is an automatically updating Zone than it must be surrounded by elements that are all Zone Boundaries.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-08-02 05:57 PM
Maybe there is something wrong with that zone instance.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-08-04 10:53 AM
laszlonagy wrote:It's the same. But I found out that you have to choose a particular type of zone so that it updates automatically - in my version AC11 Fr - n°20 zone jour 02. All other types have to update by selecting them and update manually ...
What happens if you recreate the Zone from scratch?
I once in my work forget to update some surfaces and I was asked if the surfaces were corrected ?!$ù
Well, I hope the posterior AC version will improve this.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-08-04 11:02 AM
If you go to the Area Calculation panel of the Zone Settings Dialog, you can see the Measured Area. Some Zone Stamps display that value and it will update if you modify the zone polygon.
Other Zone Stamps display the Calculated Area which is updated only with the Update Zones command.
Some Zone Stamps are using one method or the other, there are probably differences in the localized versions too.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-08-25 04:37 AM
I found that zones created automatically are trouble, they will return to whatever automatic settings were used as the base condition. Very logical, right?
So my problem was that I custom changed the zone boundary to a non-reference line limit, then the recalculate function reset them to the reference line (of course)! Losing all my work.
Drove me nuts until I realized my error, now I never use the automatic or default zones. Because I always find some corner or shaft, etc. that needs a little tweaking. Hence never an automatic zone again!
Snap
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-08-25 08:36 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-08-26 12:42 AM
You are right, "Update Zones" command is the correct syntax for a zone "recalculation".
I would really like it if the zone command could be used to quickly set a zone based on reference lines, but then arbitrarily alter the boundaries. What happens currently is that the "Update Zones" will reset itself to the reference lines, so your only option is to create a custom zone to start with.
Snap
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-08-26 04:11 AM
snapcrackle wrote:You can change the type of zone once you have placed it.
Masterscript,
Snap
So use the automatic zone to initially place the zones.
These will automatically update with "Update zones".
Then if you find you have to manually adjust a zone just change it's type from "Reference" to "Manual" and now it will not update with "Update zones".
