Kamelite
Survey point is moving when angle is changed
How come the surveypoint moves whenever the angle is changed? (I do believe it only happens when the survey point is moved from 0,0)
I'm  sure there is a reason, but what is the reason?
.Kamelite
Windows 10, Archicad 27,28 and 29
2 Replies 2
Aaron Bourgoin
the Northing and Easting is altered when you alter the Project North.
I've had better luck leaving the survey point at the file origin, adjusting project note and then moving the survey point to where you want it.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
Rhino 8.34 Mac
MacOS Tahoe 26.5.2
Kamelite
I agree. But in this case its a matter of finetuning the rotation.
It isn't a big deal, I'm curiouse to learn the logic that works in the background... Why does SP move when rotation is altered?
.Kamelite
