2005-09-15
03:56 PM
2023-05-26
03:29 PM
Rubia Torres
2005-09-16 12:02 AM
Rakela wrote:
in the dimensioning case u either hit the keybd or select the tool and most of the times u need to select horiz or vert and then u can start dimens'g....
2005-09-16 12:15 AM
2005-09-16 05:07 AM
2005-09-16 06:14 AM
2005-09-16 09:54 AM
2005-09-16 05:27 PM
Djordje wrote:When I try that with associative dimensions, they disappear. Is that only with Static dimensions?
Also:
Always remember that you can rotate dimensions after placing, whatever their original setting is.
2005-09-16 05:39 PM
When I try that with associative dimensions, they disappear. Is that only with Static dimensions?Nope.
2005-09-16 09:06 PM
Link wrote:ah, you got it Link.When I try that with associative dimensions, they disappear. Is that only with Static dimensions?Nope.
I believe it only works on dimensions that are placed by clicking on individual nodes, not on edges. So it does depend on the method ytou used to place them - I guess the logic is why would you need to rotate dims that we placed the correct way the first time, as the are when placed by clicking on wall edges, thus setting their reference vector correctly.
Link.
