Link
Tip: Using View Lists to Redefine Views
Please dismiss this if it has been mentioned before, but I thought I'd share something I have discovered recently and used succesfully.
In setting up many templates, I am defining and redefining views a lot of the time. This can be somewhat cumbersome in the Organizer, so I have turned to the View List to redefine my views and it works quite well. The best part is being able to see the status of all views in one window. Everything is interactive, so redefining is spot on.
The downfalls are that we can only redefine one view at a time, and there are no available parameters for Zooming, Floor Plan Cut Plane or Source View. Hopefully GS will include these soon!
Still it is pretty handy. Same interactivity can be used with the Sheet Index and Drawing List.
Link.
17 Replies 17
Petros Ioannou
No Mug, you'll get a T-shirt!
Great tip, Link!
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
Link wrote:
Please take a look at the attachment...
Link, that kills.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
Erika Epstein
Excellent Link!
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Stress Co_
Link:
You deserve a new graph-iSoft edition iPod mini.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Jefferson
I believe that's MR. Lateral Thinker
Here you are again Link looking at the same thing the rest of see, and wondering, and then pursuing your "what's really going on" train of thought. It's so easy to get caught up in the graphic interface and not move beyond that plane.........Nice work
What else ya got mate?
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
Kudos, Link!
You can knock off early. 😉
No doubt about it - this is the Tip of the Year!
Someone needs to give these power users the credit they deserve. Graphisoft should think about incorporating a rating system, where other users could vote on posts, for good or bad. Simply judging on the number of posts is not an accurate means of determining expertise. Just because someone posts a lot doesn't mean it good info. Give me quality over quantity anyday.
Some of the higher posters here just submit crap. This tip is a good example of delivering the essence of what we need to know to use archicad better.
Good job Link! Thanks for your contribution to this forum - keep it up!
Hunter.
Thomas Holm
TomWaltz wrote:
Link
I think it's been too long since I've said this:
You're f-ing brilliant sometimes, you know that?
Sounds like we all missed this one! Thanks, Link!
