Project data & BIM
Unable to delete layers
KeesW
I have a large project containing layers created from a surveyor's autocad drawing. This drawing was imported into my AC14 drawing because I used the survey for creating my site contours. I am now unable delete any of these layers.
Any suggestions?
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
12 REPLIES 12
Csaba Kezer
Hello guys,
We examined your problems. Unfortunately the program has been designed this way to separate the Xref from the project which results in a few difficulties when managing this.
We issued a report about this problem to the developer team.
The main principle to avoid these issues is to manage (detach) the xrefs through the xref manager before deleting or manipulating anything.
Regards,
Csaba
Csaba Kézér
Director, Global Customer Support
Da3dalus
Thank you, Csaba. It makes sense.
However, one thing I would be concerned about is people who only use ArchiCAD. We are fortunate to have a station of AutoCAD in our office, and I have lots of experience. However, some may not have access to AutoCAD, and may not even understand how Xrefs work. Based on this, it would be helpful for ArchiCAD to provide more information in linked DWGs, such as a warning about embedded Xrefs.
For these issues, I would recommend to anyone that works with DWG files regularly that they should get a DWG-native CAD program. AutoCAD is about $4000, and even AutoCAD LT is about $1000, so that's not always an option. I generally use Draftsight for editing and eDrawings for quick viewing (both from Dassault, maker of Catia and Solidworks), especially since I use a Mac… and they're FREE! That's quicker for me most of the time than tracking down AutoCAD.
I'd be curious to see what other programs people might use for checking DWGs.
Chuck Kottka
Orcutt Winslow
Phoenix, Arizona, USA
ArchiCAD 25 (since 4.5)
Macbook Pro 15" Touchbar OSX 10.15 Core i7 2.9GHz/16GB RAM/Radeon Pro560 4GB
Csaba Kezer
Here is a detailed article about the use of Xref DWG-s in ArchiCAD what you might haven't come across: www.archicadwiki.com/DWG/Import/Xref
Csaba Kézér
