Project data & BIM
Wall Type Indicator NCS 20 - Migrate to AC 25 and Up
Aaron Bourgoin
Has anyone had any success migrating older projects to AC25 and newer that use the label called Wall Type Indicator NCS20? Even if I manually load this label and its associated macros, the file's wall tags show up as missing.
Think Like a Spec Writer
AC4.55 through 28 / USA AC27-6010 USA
Rhino 8 Mac
MacOS 15.2
4 REPLIES 4
David Maudlin
Aaron:
Yes. What do you mean "the file's wall tags show up as missing."?
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I see a big black dot. missing piece placeholder dot.
Rhino 8 Mac
MacOS 15.2
Aaron:
Does the Library Manager show it as missing?
Does it show up in the Label Settings > Type and Preview?
damn. clicked the wrong button.
Yes to both questions David. I see a black dot, but I can select them and then assign the NCS label to them. This invariably results in rework as the labels have leader lines and has to be done floor by floor.
Rhino 8 Mac
MacOS 15.2
