Aaron Bourgoin
Wall Type Indicator NCS 20 - Migrate to AC 25 and Up
Has anyone had any success migrating older projects to AC25 and newer that use the label called Wall Type Indicator NCS20? Even if I manually load this label and its associated macros, the file's wall tags show up as missing.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.0 USA
Rhino 8.33 Mac
MacOS Tahoe 26.5.2
4 Replies 4
David Maudlin
Aaron:
Yes. What do you mean "the file's wall tags show up as missing."?
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Aaron Bourgoin
I see a big black dot. missing piece placeholder dot.
Rhino 8.33 Mac
MacOS Tahoe 26.5.2
David Maudlin
Aaron:
Does the Library Manager show it as missing?
Does it show up in the Label Settings > Type and Preview?
David
Aaron Bourgoin
damn. clicked the wrong button.
Yes to both questions David. I see a black dot, but I can select them and then assign the NCS label to them. This invariably results in rework as the labels have leader lines and has to be done floor by floor.
Rhino 8.33 Mac
MacOS Tahoe 26.5.2
