Project data & BIM
Warning Popups
Rakela Raul
Is there any way to eliminate all warnings:
'errors occurred last operation" , "hotlinks not found" (this i know how to kill)
, "jpegs/pdfs not found at this location", etc.
When i open a file i dont want to perform more than one click, regardless of all the file errors....i do recognize that warning are a must for my own good, but too many clicks !!
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
23 REPLIES 23
ArchiSuad wrote:
There is no way to eliminate all error messages. I had an instance where the "Errors occurred ..." message showed up every time I opened my elevations and the only way to eliminate the error message was to fix the error. Which I did.
I have happening on one of my files - I think that it's because of the cadimage wall acessories since they have caused problems in teh past but how do I tell when all it says is "errors occured"?
Is there anyway to identify what exactly is causing the errors?
A new warning from a Cadimage detail add-on...
Stress Co_
Hey Mate,
At least you found 3 of your danglers.
~Archiben couldn't find any.
Marc Corney, Architect
Red Canoe Architecture, P. A.
I don't feel so bad now.
Tom Krowka
Would really be helpful if AC would highlight the offending part, line, whatever. Would narrow down the search.
Also would be very helpful if the error message would actually hightlight the offending script. Many times it refers to "line number____" which I can't find in the script for the object anyway.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
__archiben
Stress wrote:
Hey Mate,
hey! i'm not sure that having three of them is anything to be proud of either!
b e n _ f r o s t
"Edit GDL Library Parts" toolbar..."Goto" Line Number Found this quite by accident one day!!
David Maudlin
When you have opened a library part, this command is in the Edit Menu along with other helpful GDL editing commands (may depend on your Work Environment).
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Tom Krowka
Will give it a try. Thanks for the heads up.
TK.
Thomas@wkarchwk.com
www.walshkrowka.com
Archisuad, how did you fix it if I may ask?
