Project data & BIM
When I ctrl+M+shift after hotlink, the door changes
LeeJaeYoung
This is a case of ctrl+shift+D after hotlink and then ctrl+M.
this is door entrance door 25.
this is bbb.pln ( aaa.mod -> bbb.pln : hotlink)
The one above is ctrl+shift+M
The bottom one is ctrl+shift+D followed by ctrl+M
this is ccc.pln ( aaa.mod -> bbb.pln -> ccc.pln : hotlink)
AC27 on window 11
15 REPLIES 15
When a new Hotfix or Update comes out, there are Release Notes that list all the issues and bugs that were fixed by it. You can go through the list and see if the issue you are interested in was fixed.
thank you so much
AC27 on window 11
Peter Baksa
this is a known bug, AC_Wall_Direction_Type will be wrong with Ctrl-Shift-M.
There is a workaround: move the hotlink after creating the mirrored copy..
PƩter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
Thank you for the reply.
What does "this is a known bug" mean?
Are you saying it wasn't fixed in 26?
Does that mean I know but can't fix it?
AC27 on window 11
Peter Baksa
It means others have reported it too and there is no fix in the latest released versions/updates.
When it will be fixed I don't know, it depends on many factors, please contact support about that.
PƩter Baksa
thank you so much ^^
AC27 on window 11
