Scott Newland
Where is the "Document" pulldown?
I was watching a video tip from www.actemplate.com on changing window and door ID's and the tip involved changing a lot of element ID's at once, using Document>Schedules and Lists>Element ID Manager. This must be based on an older version because ArchiCAD 14 doesn't have the Document pull-down. I can find the Element ID Manager under Options>Work Environment and I've since added it one of my toolbars, but did the Document pulldown go away?
Scott J. Newland
Mac OS 26.5.1
ArchiCAD 29
iMac running OS 11.5
David Maudlin
Scott:
Go to Work Environment and apply the Standard Profile 14, it is there.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
If you do not want to apply the complete Standard Profile 14 you could just apply the Standard Command 14 as your Command Layout Scheme
