2026-08-20 03:13 PM - last edited on 2026-08-21 02:55 AM by Barry Kelly
Solved! Go to Solution.
2026-08-21 09:21 AM - edited 2026-08-21 10:39 AM
Thanks for helping guys,
I believe the bug here is with the specific Dutch variation of the Window/Door objects. Some of them manage to keep the surface, but most go to "MISSING" after reindexing.
2026-08-21 03:01 AM
Re-indexing should work as you expect.
Any element that was using index 14 should now be using index 11002.
I am not sure but, if you are using hotlink modules, you will probably also need to re-index the original hotlink source file as well.
And if it is a teamwork file I would probably save it out as a PLN and then re-share afterwards.
2026-08-21 04:42 AM
i usually avoid re-indexing in the middle of a job, however if i've needed to i've had success with duplicating the surface and reindex as desired. then i delete the original surface and replace with the new. this seems to work all the time, and will also update favourites, etc. as well.
