Tom Krowka
Xref Translator
Translator settings.....used to be a translator manager in v9. Don't see it anywhere.....wha' happened to it.
Also, translators have some intriguing new settings. In the explanation box at the bottom of the translator dialogue box within the xref box it says one of them should be used if the lines/ arcs. etc. will be modified after placing.
Does that mean modified in AC10, and if so, how are edits accomplished. I can't seem to do anything to the drawing entities xref'd in AC. I can select, but that is all. Xref layers are unlocked and groups suspended.
Or does that mean the xref will be modified in Autocad.
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
1 Reply 1
Look in the file menu / file special...
