Project data & BIM
Xref layers deletion
I deleted an Xref without choosing to delete its attributes. How do I now delete all the Xref layers?
13 REPLIES 13
Eduardo Rolon
Another option is to see if you have Hot linked Modules attached to the file that are the ones that have the Xrefs.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
sarahric
OK, does work. Apparently you've got to press Apply before ok. Is this a Mac thing?
ArchiCAD 18/Windows 7/16GB Memory/i5 3.2GHz Processor/NVIDIA GeForce GT 610
Eduardo Rolon
No it is a n Archicad thing…
AC28 US/INT -> AC08
another Moderator
Cosmin Ghioanca
ejrolon wrote:
I think that it was mentioned on another post, the trick to remove X-Ref layers is to delete them using Attribute Manager instead of the Layers.
I think it is a bug that only happens when the file was "Teamworked" at some point.
I also had this problem where I detach the Xref and the layers don't disappear. So I did just this and works just fine. It also took me less than 30 sec.
My OCD wanna thank you so much right now!
Archicad 6-6.5-9-10-11-13-15-16-18-20-21-22-23
64-bit OS Windows 10 Pro
AMD Phenom II X4 965 3.40 GHz CPU
AMD Radeon HD 5670 GPU
Samsung SSD 860 EVO 512(500)GB SATA
WDC WD10EALX-009BA0 1TB(931)GB SATA
WD MyPassport 259F 1TB(931)GB USB3
