2008-02-25
07:03 PM
2023-05-26
03:27 PM
Rubia Torres
2012-03-21 02:33 AM
2012-03-21 02:34 AM
2012-03-21 02:35 AM
sarahric wrote:No it is a n Archicad thing…
OK, does work. Apparently you've got to press Apply before ok. Is this a Mac thing?
2020-05-14 11:19 AM
ejrolon wrote:I also had this problem where I detach the Xref and the layers don't disappear. So I did just this and works just fine. It also took me less than 30 sec.
I think that it was mentioned on another post, the trick to remove X-Ref layers is to delete them using Attribute Manager instead of the Layers.
I think it is a bug that only happens when the file was "Teamworked" at some point.
